I know that there are several options out there for good controllers for the K40 type lasers. I am wondering if anyone has used a 3D printer main board to control their K40.
I ask because I am looking to get a K40, and I have seen a few used options. I assume they would have an old style board. I am not interested in spending as much for the board as I pay for the K40.
I have a bunch of control boards on hand, just wondering if I can use one of them.
Some of the first laser boards were based on the Arduino running GRBL. Anything is really possible depending on your skills.
What sort of boards? If they are RAMPS style boards based on the ATMEGA256 then you can run the latest version of Marlin or GRBL-Mega on them. Marlin will control a CNC just as it will a 3d-printer. My mini CNC used a cheap RAMPS board and grbl-mega for a year without problems.
Hi,
Alternatively you can also use a (very cheap) ESP32 board to embed FluidNC to control your laser.
Have a look here : Retrofitting an old laser engraver | Hackaday.io
I designed the control board. Cannot be simpler nor cheaper !
I’ve had the stock M2 Nano in my K40, a Smoothieboard clone running Smoothieware and I’ve had 2 other 3DP boards in it running Remora firmware on the 3DP boards and LinuxCNC on a Raspberry Pi.
So there are many options beyond what I’ve tried/done it just depends on your skill sets and/or ability to research and learn.
Smoothie Board has been working swell in a salvaged Glowforge.
Salve io uso una mks dlc32 per la k40 mi consente di usare lightburn
