Is anybody aware of an approximate beam waist at the focal point for a stock K40? Am curious if anybody has worked this out – based on my first few days of testing, it looks like maybe 0.5 to 0.75mm? I understand that with its Gaussian distribution, the ablation will be wider at higher powers. Any spec sheets on the focusing lens that comes with the K40? Am wondering what the theoretical minimum is on the beam, as this plays into the systems overall level of detail / “resolution”. Thanks!
I set my beam width at .5mm in LaserWeb
Since all optics,alignment, and tube strengths vary it’s always going to be an approximation. The best I could get with stock k40 equipment with tuned in alignment was about .4mm based of measurements of circles and squares I made while testing in wood and acrylic while I was first getting started
The k40 is manufactured by several companies so tubes mirrors and lenses vary in spec and quality so it’s all guess work
I see. I imagine with custom optics, the beam waist could be brought down. Or truncating the beam?
Some interesting data here also:
https://www.troteclaser.com/en-us/laser-machines/laser-accessories/focus-lenses/
This video is informative: https://youtu.be/61bGzWicRRk
If you do a ramp test with a piece of card stock you should be able to figure it out fairly easily.
@Nedman Good idea – I could do a series of lines with increasing power levels. How can I have the laserdrw software draw a single “dot”? If I draw a very small circle, it still seems to try and draw/pass over it a couple of times instead of firing once and moving on to the next dot.
@Austin_Baker I was thinking that you would take a piece of cardstock and place it at an angle with the bottom below the focus and the other end above the focus. Then vector draw a line up the card. Would need to play with the power and speed to get a good sharp mark around the focus without too much extra burn. Then measure the linewidth at the narrowest spot.
@Austin_Baker any lens that is designed for 10600 and will fit the lens mounting will theoretically work. What are you wanting to accomplish by getting spot size and lens changes.
@Austin_Baker you can find the kerf (dot size) by cutting a square and then measure the inside piece and outside piece, subtract the two and then divide by two. That will give you the kerf not the optical spot size? Depends if you want the optical size or the imaged size. Material makes a big difference here.
@donkjr That might yield useful information. Increasing the power increases the effective beam waist. Can anything done at high speed high power be done at low speed low power with the same quality? As long as the ratio is maintained, right?
