Integrate lighting into my Herculien question.
Integrate lighting into my Herculien question. I want to add some LED lighting potentially some white led strips up top. But I know little about electrical. I am running. A 24v PSU and all led strips are 12v is this an issue if I’m running them through the Aztega v3?
I got 24v led strips from aliexpress. They are so bright I run them at S60 output. S254 was blinding. The whole roll cost me $10. If you were closer I would ship you some.
For the extrusion drill guides am I right to assume the one with the 4 small holes is to mark where the smooth rides come through the frame?
@Derek_Schuetz yes. They create the pilot holes. You can tell which hole to use by holding the corresponding corner bracket up.
Also use a hole saw or and endmill bit to drill the large hole. A regular bit will walk since it is half on, half off a rib in the extrusion. You will need to use a drill press.
Ok I have a drill press. What size hole should I do 3/4" seems too big and that’s the smallest Holesaw I can find
I used a 1/2" regular bit. That’s why I am recommending you avoid it. I fought it walking like crazy. The shaft is 10mm, so I wanted at least 1mm clearance on each side minimum.
Did you have a drill press or did you do it with a hand drill?
With a drill press, with a x/y adjustable vice and mount. But the slope on the tip of a standard spiral bit will put a lot of side force once you hit the vertical rib. Again, you CAN do it with a standard bit, I did… But it was such a royal pain. So I will recommend against it as strongly as I can. I took it super slow (like 2 hours for 4 holes slow) and I still had bit walk.
Ok I’ll take your word and try to find a 1/2 Holesaw
Slotdrill / centre cutting endmill? Will still need to take it slow but it won’t be influenced by the tip like a standard drill bit would…
