I have a 10W laser tree machine at home, but i think the speed little low. I want to install a 30W power head on my machine . However, the supplier suggested that I buy a 30W machine. Should I go for assembling it myself or buy the machine?
Welcome to the ‘Rabbit Hole’.
It depends on your skill level and your machine.
Your question is sort of blind…
You will need to provide much more detail about your machine, the laser you plan to install……
Merry Christmas
The problem you have is the mass of the 30W module is large compared to the 10W. It’s likely that you have to slow it down to work properly as I doubt you can use the same values in acceleration.
