insert svg format (inkscape) to LW4, why the size different with original size?
Check PPI: http://cncpro.co/index.php/57-documentation/initial-configuration/laserweb-configuration/file-settings
Good to know. Had problems in LW3 too. (https://plus.google.com/+HrishikeshBidwe/posts/RoVy49LTzjk) Couldn’t find a solution until now, but doing no jobs at the moment, so no bug hunting.
Hope it’s working better in LW3. I have to try it.
Can you upload the file ?
even follow what http://cncpro.co wrote they, for svg dpi 96, still same result not actual size
the file
https://drive.google.com/open?id=0B_l0DiB8SLV5XzIxUmlaT1FBbUk
For me, dpi 25,4 works.
+Roberto Fernandez​
that one for BMP right?
I tried to open your file. It works with 90ppi which is related to the old inkscape version: Inkscape 0.91 and earlier used a value of 90 pixels per inch.
from Units In Inkscape - Inkscape Wiki
Update to a recent version to use 96dpi or set it at 90. #RTFM
@adam_ian no, for svg files. For bitmap i have 600 dpi or 300 dpi, depend of the file.
solved, update the Inkscape, set to ppi 90
