I am looking through the documentation, but unable to find what I am looking for. I am coming from Repetier.
The issue is that I get some scaling issues in the Z and Y axis. I’ve adjusted the diagonal rod length to an average but under repetier I was able to set individual rod length adjustments via DELTA_DIAGONAL_CORRECTION_ABC. Does Smoothieware have an ability to do this as well?
I don’t think so. But I might not be reading the code properly. That said, if I am able to adjust the individual diagonal rod length, I can’t do it via g-code. Is that correct?
I think maybe what I was hoping for was a g-code, or parameter to adjust. Similar to:
M665 L297.5000 R139.3101
with some parameters X Y Z (for example) which could allow me to adjust the individual lengths.
