Hello everyone, I’m new here
I have an Eleksmaker a3 pro with firmware 1.1f, I downloaded LW to start recording my designs in DXF (done in autocad), the problem has arrived when I sent the order of engrave.
For some strange reason the engraving is much larger than the original file. For example: my design measures 25mm x 40mm but the machine comes out at 150mm x 80mm (it’s an example, they are not real numbers).
What am I doing wrong? Can you help me? Thank you
P.D: Sorry for my bad english, i use google translator…
