Incomplete path/trace
Chillipeppr is great! Congratulations!
I had found a micrometric short on start-end point of some paths during signal routing. What do I do to overlap start-end tracing? It is hard to find; normally after soldering =(
Thanks
David
When you say this, do you mean after the milling of a PCB using ChiliPeppr? Or do you mean prior to milling in the 3D viewer where you’re using the Eagle BRD Widget to convert the board to Gcode?
Thanks for return, John.
After the milling. Is like if the milling path had finished before the start point. Using a conical bit, the tip diameter is hard to define. Sometimes is broken but cuts fine. I suggest you add a couple of initial code path lines to the end, overlapping any diameter differences.
Congratualtions for ChiliPeppr!
Best Regards,
David
Ahh, yeah, i’ve had that problem too. You could try adding a ground plane to your PCB design and then the Eagle widget generates toolpaths for that polygon as well giving you a reverse path, which typically solves that for me, but does make the milling take longer.
How can I send img to you? Thanks
You can just paste from your clipboard right into this forum.
Hi John. Take a look. There are many shorts like this. Can you give the option of two passes. The secondo could be faster. Thanks.
David
I believe if you create a ground plane, you do get 2 passes because it calculates the trace path and then the ground plane inverse path. I used that in the past to get those dingleberry pieces of copper milled away.
Also, I would sometimes just run the job a 2nd time. Usually I would lower by Z by 0.05mm on the 2nd run just to get even cleaner traces.
Thans, John. I’ll try the ground plane strategy.
Hi John. How are you?
I cannot launch chilipeppr today. Any issue, or is me
David
Bottom posting on a many year old thread is not the best way to get peoples attention.
Please start a new thread and include a real description of what is happening, what version of chillipepper you have, what OS. What might have changed since the last time it worked.
Hi @DavidL_Dewey give it a go now. Looks like rawgit.com disappeared as an online service which was used to slingshot raw github files to the 3D viewer workspace. I changed it to raw.githubusercontent.com and now it’s working again.
For the record, ChiliPeppr really isn’t supported anymore.
-John
