In the “port list” there is a drop down where you select “tinyg”, the other options being “default”, “marlin”, “tinygg2”, etc. I have a DUE board flashed with the latest stable TinyG2 code. I can connect to it with cool term and do a “$$” and pull the config no problem. If in the drop down I have selected “tinyg” then I can connect to it from chilipeppr and control it no problem. BUT when I select “tinygg2” from the drop down (which I would expect as this is the G2 code) it will not respond to any commands and seems hung.
Can someone clarify what the drop down is used for and any ideas why it would not work with “tinygg2” selected, but does work when “tinyg” is selected?
