In lightBurn 8.03 with my dell i5 laptop running windows 10. When I open the program it does not show the color bar at the bottom of the screen until I hit the minimize button twice. Then when i click on any object on the work space that item shifts up and I can’t see the color bar again. Any suggestions to fix this?
You can drag the color bar anywhere you want. I put mine to the left.
Happens to mine sometimes I toggle the full screen button and it comes back
LightBurn does not maximize like it is supposed to. It is the same every time I open it. I think it is a program error but I am not sure.
Close the “shape properties” window, or tab it / dock it behind one of the others. The content of that window changes when you select something, and it’s “minimum height” restriction changes to match. We’re likely going to change the way this control is coded to get rid of this, but it’ll take some time.
Thanks for your response.
I removed the shape properties and it still opens full screen hiding the the cut palette. I also removed the cut palette and it still cuts off the bottom of the program screen. Is this a bug in the latest release and can I install an older version to fix this for now?
It remembers the size and position. Shrink the window size by dragging the top edge down, then pull the whole window up, and that should fix it,
