I'm working on CP+grbl1.1f.I found a problem.After I passed an eagle-brd and do autolevel,
I’m working on CP+grbl1.1f.I found a problem.After I passed an eagle-brd and do autolevel,
I can’t push it’s generated-gcode+autolevel data to CP’s workspace to run the final gCode (the workspace gCode window always show old data).How to update the CP’s workspace ? Please help.
it might help if you clear the cache first.
if there are javascript errors this will show up in the javascript console. please log those errors and post them back here.
as a work around, you can view the auto-levelled gcode in the post-run tab, copy it and then paste it into the workspace via the button at the top left widget.
it work,thks.
In particular, wipe out the localstorage for http://chilipeppr.com or at least just wipe the “last-imported” value in case that’s corrupted.
