I’m working on a project to drive 420 to 480 APA102s in a single string.
I’m using an Arduino Uno with hardware SPI and I run out of RAM around the 400 pixel count. The individual control of the LEDs is not super critical, if the CRGB leds[NUM_LEDS]; array was half the size, that would be great.
I’d like to modify (or create a copy of) FastLED.show() so that it writes out 2 pixels of data for each member of the leds[] array.
But I can’t find the FastLED.show() implementation where it writes out the SPI data.
Thanks, Marc. It’s one long strip. The write time is fine. I just need the LEDs spread out.
I have a Teensy 3.1 that I might mess around with. I was just hoping to develop the code on the Uno, then port it over to a micro Leonardo clone. The Teensy intimidates me.
Holy Moly. I’ve got it working on a Teensy3.1 !!! Dang that thing is fast. I can’t believe it was that easy!
I’m not driving APA102s with anything but a Teensy from now on.
Now I just have to find the power to run 8 meters of 144 led/m instead of 60led/m! This just got too easy.
