I’m using Kisslicer, and had to reinstall due to my virus software deleting the executables for no good reason. Since then, my g-code doesn’t include anything to heat the bed. I’ve been manually heating my bed in repeteir host, then starting my print. In my material settingm I have the Bed set to 60, but when I run a print, it homes and heats up the extruder with no concern over the heat bed. Anyone have any suggestions?
I have had my virus software, Avast, attack my KISSlicer and I had to reinstall it to get it working. I do not have a heated bed and I heat my hotend manually in RepG before prints. So I guess the only thing I have to contribute is I switched to MSE virus software.
When you reinstalled, you probably blew away the initial gcode that you used to have under the printer Gcode tab. Your gcode should have a token in there somewhere.
Ah, I definitely do not have a bed token, need to grab some old gcode and pull some lines out.
Thanks
Among a few other printer specific things like nozzle purging I have this in my prefix g-code;
M104 S ; set extruder temp
M190 S ; set bed temp and wait
And under Select extruder g-code I have this;
M109 S ; set extruder temp and wait
