I’m trying to get FastLED working with NodeMCU using the Arduino IDE and unfortunately I’m not able to compile the ‘Blink’ example program and I get pages of errors.
I’m using Arduin 1.6.5 and the 3.1.0 version of Fast LED
Here is the mass of errors - I must be missing something fundemental - what is it!! It compiles ok for the Arduino uno but not for the Node MCU or ESP8266 but Iunderstand that this hardware is now included?
In file included from Blink.ino:1:0:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:12:2: warning: #warning FastLED version 3.001.000 (Not really a warning, just telling you here.) [-Wcpp]
In file included from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:34:0,
from Blink.ino:1:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/led_sysdefs.h:22:2: error: #error “XTENSA-architecture microcontrollers are not supported.”
In file included from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:42:0,
from Blink.ino:1:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/platforms.h:22:2: error: #error “XTENSA-architecture microcontrollers are not supported”
In file included from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:53:0,
from Blink.ino:1:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastspi.h:98:2: warning: #warning “No hardware SPI pins defined. All SPI access will default to bitbanged output” [-Wcpp]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:483:2: warning: #warning “No pin/port mappings found, pin access will be slightly slower. See fastpin.h for info.” [-Wcpp]
In file included from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/pixeltypes.h:5:0,
from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/controller.h:8,
from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:37,
from Blink.ino:1:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/lib8tion.h:832:17: error: new declaration ‘uint32_t millis()’
uint32_t millis();
In file included from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/led_sysdefs.h:36:0,
from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:34,
from Blink.ino:1:
C:\Users\SC-Home\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266/Arduino.h:191:15: error: ambiguates old declaration ‘long unsigned int millis()’
unsigned long millis(void);
In file included from C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:38:0,
from Blink.ino:1:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:29:11: error: ‘RwReg’ does not name a type
volatile RwReg *mPort;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:30:11: error: ‘RoReg’ does not name a type
volatile RoReg *mInPort;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:31:2: error: ‘RwReg’ does not name a type
RwReg mPinMask;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:42:19: error: ‘RwReg’ does not name a type
typedef volatile RwReg * port_ptr_t;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:43:10: error: ‘RwReg’ does not name a type
typedef RwReg port_t;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:54:26: error: ‘port_ptr_t’ does not name a type
inline void hi(register port_ptr_t port) attribute ((always_inline)) { *port |= mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:54:37: error: ISO C++ forbids declaration of ‘port’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:55:26: error: ‘port_ptr_t’ does not name a type
inline void lo(register port_ptr_t port) attribute ((always_inline)) { *port &= ~mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:55:37: error: ISO C++ forbids declaration of ‘port’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:56:27: error: ‘port_t’ does not name a type
inline void set(register port_t val) attribute ((always_inline)) { *mPort = val; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:56:34: error: ISO C++ forbids declaration of ‘val’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:58:31: error: ‘port_ptr_t’ does not name a type
inline void fastset(register port_ptr_t port, register port_t val) attribute ((always_inline)) { *port = val; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:58:42: error: ISO C++ forbids declaration of ‘port’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:58:57: error: ‘port_t’ does not name a type
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:58:64: error: ISO C++ forbids declaration of ‘val’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:60:2: error: ‘port_t’ does not name a type
port_t hival() attribute ((always_inline)) { return *mPort | mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:61:2: error: ‘port_t’ does not name a type
port_t loval() attribute ((always_inline)) { return *mPort & ~mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:62:2: error: ‘port_ptr_t’ does not name a type
port_ptr_t port() attribute ((always_inline)) { return mPort; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:63:2: error: ‘port_t’ does not name a type
port_t mask() attribute ((always_inline)) { return mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘void Pin::_init()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:35:3: error: ‘mPinMask’ was not declared in this scope
mPinMask = digitalPinToBitMask(mPin);
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:36:3: error: ‘mPort’ was not declared in this scope
mPort = portOutputRegister(digitalPinToPort(mPin));
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:37:3: error: ‘mInPort’ was not declared in this scope
mInPort = portInputRegister(digitalPinToPort(mPin));
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘void Pin::hi()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:48:54: error: ‘mPort’ was not declared in this scope
inline void hi() attribute ((always_inline)) { *mPort |= mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:48:63: error: ‘mPinMask’ was not declared in this scope
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘void Pin::lo()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:49:54: error: ‘mPort’ was not declared in this scope
inline void lo() attribute ((always_inline)) { *mPort &= ~mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:49:64: error: ‘mPinMask’ was not declared in this scope
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘void Pin::toggle()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:52:58: error: ‘mInPort’ was not declared in this scope
inline void toggle() attribute ((always_inline)) { *mInPort = mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:52:68: error: ‘mPinMask’ was not declared in this scope
inline void toggle() attribute ((always_inline)) { mInPort = mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘void Pin::hi(int)’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:54:78: error: invalid type argument of unary '’ (have ‘int’)
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:54:86: error: ‘mPinMask’ was not declared in this scope
inline void hi(register port_ptr_t port) attribute ((always_inline)) { port |= mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘void Pin::lo(int)’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:55:78: error: invalid type argument of unary '’ (have ‘int’)
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:55:87: error: ‘mPinMask’ was not declared in this scope
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘void Pin::set(int)’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:56:74: error: ‘mPort’ was not declared in this scope
inline void set(register port_t val) attribute ((always_inline)) { mPort = val; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘void Pin::fastset(int, int)’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:58:104: error: invalid type argument of unary '’ (have ‘int’)
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In member function ‘virtual bool Pin::isSelected()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:67:39: error: ‘mPort’ was not declared in this scope
virtual bool isSelected() { return (*mPort & mPinMask) == mPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:67:47: error: ‘mPinMask’ was not declared in this scope
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: At global scope:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:155:9: error: ‘RwReg’ does not name a type
static RwReg sPinMask;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:156:18: error: ‘RwReg’ does not name a type
static volatile RwReg *sPort;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:157:18: error: ‘RoReg’ does not name a type
static volatile RoReg *sInPort;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:166:19: error: ‘RwReg’ does not name a type
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:167:10: error: ‘RwReg’ does not name a type
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:179:33: error: ‘port_ptr_t’ does not name a type
inline static void hi(register port_ptr_t port) attribute ((always_inline)) { *port |= sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:179:44: error: ISO C++ forbids declaration of ‘port’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:180:33: error: ‘port_ptr_t’ does not name a type
inline static void lo(register port_ptr_t port) attribute ((always_inline)) { *port &= ~sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:180:44: error: ISO C++ forbids declaration of ‘port’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:181:34: error: ‘port_t’ does not name a type
inline static void set(register port_t val) attribute ((always_inline)) { *sPort = val; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:181:41: error: ISO C++ forbids declaration of ‘val’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:183:38: error: ‘port_ptr_t’ does not name a type
inline static void fastset(register port_ptr_t port, register port_t val) attribute ((always_inline)) { *port = val; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:183:49: error: ISO C++ forbids declaration of ‘port’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:183:64: error: ‘port_t’ does not name a type
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:183:71: error: ISO C++ forbids declaration of ‘val’ with no type [-fpermissive]
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:185:9: error: ‘port_t’ does not name a type
static port_t hival() attribute ((always_inline)) { return *sPort | sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:186:9: error: ‘port_t’ does not name a type
static port_t loval() attribute ((always_inline)) { return *sPort & ~sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:187:9: error: ‘port_ptr_t’ does not name a type
static port_ptr_t port() attribute ((always_inline)) { return sPort; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:188:9: error: ‘port_t’ does not name a type
static port_t mask() attribute ((always_inline)) { return sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In static member function ‘static void FastPin::_init()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:160:3: error: ‘sPinMask’ was not declared in this scope
sPinMask = digitalPinToBitMask(PIN);
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:161:3: error: ‘sPort’ was not declared in this scope
sPort = portOutputRegister(digitalPinToPort(PIN));
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:162:3: error: ‘sInPort’ was not declared in this scope
sInPort = portInputRegister(digitalPinToPort(PIN));
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In static member function ‘static void FastPin::hi()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:172:61: error: ‘sPort’ was not declared in this scope
inline static void hi() attribute ((always_inline)) { *sPort |= sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:172:70: error: ‘sPinMask’ was not declared in this scope
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In static member function ‘static void FastPin::lo()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:173:61: error: ‘sPort’ was not declared in this scope
inline static void lo() attribute ((always_inline)) { *sPort &= ~sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:173:71: error: ‘sPinMask’ was not declared in this scope
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In static member function ‘static void FastPin::toggle()’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:177:65: error: ‘sInPort’ was not declared in this scope
inline static void toggle() attribute ((always_inline)) { *sInPort = sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:177:75: error: ‘sPinMask’ was not declared in this scope
inline static void toggle() attribute ((always_inline)) { sInPort = sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In static member function ‘static void FastPin::hi(int)’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:179:85: error: invalid type argument of unary '’ (have ‘int’)
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:179:93: error: ‘sPinMask’ was not declared in this scope
inline static void hi(register port_ptr_t port) attribute ((always_inline)) { port |= sPinMask; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In static member function ‘static void FastPin::lo(int)’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:180:85: error: invalid type argument of unary '’ (have ‘int’)
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:180:94: error: ‘sPinMask’ was not declared in this scope
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In static member function ‘static void FastPin::set(int)’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:181:81: error: ‘sPort’ was not declared in this scope
inline static void set(register port_t val) attribute ((always_inline)) { sPort = val; }
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h: In static member function ‘static void FastPin::fastset(int, int)’:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:183:111: error: invalid type argument of unary '’ (have ‘int’)
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:191:23: error: ‘RwReg’ does not name a type
template<uint8_t PIN> RwReg FastPin::sPinMask;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:192:32: error: ‘RwReg’ does not name a type
template<uint8_t PIN> volatile RwReg *FastPin::sPort;
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/fastpin.h:193:32: error: ‘RoReg’ does not name a type
template<uint8_t PIN> volatile RoReg FastPin::sInPort;
Blink.ino: In function ‘void setup()’:
Blink:22: error: ‘WS2812B’ was not declared in this scope
Blink:22: error: no matching function for call to ‘CFastLED::addLeds(CRGB [16], int)’
Blink.ino:22:62: note: candidates are:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:172:129: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER, unsigned char SPI_DATA_RATE> CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER, uint8_t SPI_DATA_RATE > CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:172:129: note: template argument deduction/substitution failed:
Blink:22: error: template argument 1 is invalid
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:184:95: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN > static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:184:95: note: template argument deduction/substitution failed:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:196:113: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER > static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:196:113: note: template argument deduction/substitution failed:
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:292:25: note: template<template class CHIPSET, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:292:25: note: template argument deduction/substitution failed:
Blink:22: error: wrong number of template arguments (3, should be 2)
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:298:25: note: template<template class CHIPSET> static CLEDController& CFastLED::addLeds(CRGB, int, int)
static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\SC-Home\Documents\Arduino\libraries\FastLED/FastLED.h:298:25: note: template argument deduction/substitution failed:
Blink:22: error: wrong number of template arguments (3, should be 1)
