I’m trying to fuse together a darth vader face on a mug to make for a friend and I’ve seen crazy things done with meshlab… only problem is i’m not that great with it. i’m looking for youtube tutorials on the matter… but i am not finding what i need. so, some help? anyone?
Can help
Anything for our Lord Vader
@Anuj_Deshpande u da maaaan! I’ll contact you on hangouts as soon as I get home. Many thanks, sir!
I would use open scad. It would be a few steps… I will give it a try. Links to models?
sooo, i had a quick look in meshlab and i managed to make this: https://drive.google.com/file/d/0B2MWsxvLpodAS0ZQVklyZ25fQXc/view?usp=sharing
my issue, now, is to delete the interior. i tried and tried and managed to delete some faces, but how do I remove up to where the faces meet
me again, this is where I got and I have no clue as to how to fix it:
https://drive.google.com/file/d/0B2MWsxvLpodAbXN3NXNfWlFIS2s/view?usp=sharing
@Adrian_Ciubotariu did you use the Combine option followed by brush select and then delete ? I haven’t had time to look at it yesterday, but I think instead of ^, we should use the boolean functions and split the Vader in 2.
@Adrian_Ciubotariu are you using one of the MakerBots ?
@Anuj_Deshpande yep. Combine then brush to remove. Since tutorials are scarce… This is the best I could do.
Is the question related to what printer I use? It’s a DIY.
