I'm trying to figure out where to connect a filament runout sensor on a
I’m trying to figure out where to connect a filament runout sensor on a mks sbase v1.3 board.
The code on smoothie says pin 1.30 to pause and 1.31 to resume. Those are used by the display on exp1 so thinking it’s not what I’m looking for.
If I said pin 1.22 it’s conveniently next to ground but need it to pause then wait once filament is reloaded it needs to resume from the display. Which I’m hoping you’ll say is pin 1.31
In short I want it to work like it does in marlin.
No even one answer. It is because no one has figured it out / Knows or is this an indication that smoothie is not as functional as is made out to be.
