I'm searching for inspiration, guys.
I’m searching for inspiration, guys. I wonder what carriages you guys are using except from the standard one. I’m missing motivation and creativity lately and already spent some hours drawing and throwing away ideas. My last design was based on the one from +Walter Hsiao which basically was great but failed at cooling the E3D in the right way. Also the mounting of my special kind of Bed Level Sensor (the small IR sensor) wasn’t that good. I liked the dual blower setup for part cooling and I thought it would be worth keeping it.
If you hadn’t seen the design, you can find some stuff here https://plus.google.com/+FrankHelmschrott/posts/ZCLFZ7t5qX9
Basically i need better ventilation (or better air throughput) on the back of the E3D and a better place to mount the IR sensor board. Also I will probably switch back to the graphite bushings or even to SDSPI if I can get some.
Anyways - would be happy to see your carriages if you did any special ones.
Here’s my version of the space invader - might help
http://a360.co/2jcPZO5
Hey @Matt_Miller thanks. Does the cooling work for you? Your cooling holes in the back aren’t much bigger than mine and for me that didn’t work at all.
Well, I can’t say it’s perfect as I’ve never measured it. And I’ve only put PLA through it. But it’s never clogged on me.
If it runs with PLA and also on small spikes or smaller elements like the benchy window posts it’s probably good. that’s where I got problems.
You’ve got much more room behind the hotend which lowers the pressure on the axial fan which should make the biggest difference. I could maybe take some ideas to redo mine completely. Thanks anyways for posting. it’s always good to see how others work.
Hey, just glad I could help in some fractional way. And if you’re having problems getting those sintered bearings let me know. I can ship something from the US to you.
That’s a great offers - thanks so much. I’m currently evaluating some similar IGUS bearings. I’m kind of an IGUS fan and will see if they can work for this. If not I’ll definitely come back to your offer.
Cool. Just let me know - happy to help!
