I'm saving up to get the next size up from the K40.  Can anyone
I’m saving up to get the next size up from the K40. Can anyone with one let me know how much better they are and can you do more on it.
Next size being in tube power? or work piece area?
Tube power which inclue lage work area
I’m totally impressed with my x700. The k40 has been officially retired. It’s a dream to use a larger machine. You won’t be disappointed.
Where did you purchase it from. Im in the UK
Sanvan Corp. They shipped it from San Bernardino CA. Not sure but I’m assuming they service Europe as well. From China.
Thanks, is similar to the one your on about.
http://www.ebay.co.uk/itm/80W-Co2-Laser-Cutter-700x500mm-Laser-Engraver-Laser-Cutting-Machine-High-Quality-/201621735997?hash=item2ef1978a3d:g:ZwMAAOSwbsBXlCTk
Looks just like it. Productivity is through the roof. Very happy
What Wattage was it and what do you need to get it up and running… Is it faster as well as a larger area that increases productivity. What software do you use with it.??? Thanks
If you can see the ad - it tells you all that stuff
Hello Greg I know I posted it, I wondered if it was the same wattage as ben had bought
Ah I see ! Looks like a nice machine.
yep I want one.
yep same machine. It runs RDworks with the corel plug in. But no need to use corel. I use illustrator cc and save native and import to rdworks. No converting to illustrator 10 required. I added a LAN dongle and assigned it a private IP address and can use it from any computer directly. Stunningly easy to use compared to k40.
The dongle to webify it: https://www.amazon.com/gp/product/B014SK2H6W/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
