Im not sure if this a feature if it is i haven’t found i’d love to see an option to input a sheet size and cut/engrave multiple copies of the same object. Ofcourse i can manually do this but a feature to allow me to select how may copies i want of the same object would be cool. The waterjet i use at work allows you to set a sheet size and then draw an object and you can then fill the sheet with that object. Just a thought.
We don’t have that in LW. That’s would be called “array”. Most design and cad software do that.
