I'm not sure if these are at retract or restart locations,
I’m not sure if these are at retract or restart locations, but they appear on the print just as advertized on the g-code preview.
Any advice for getting rid of these (besides sanding)?
Is that Cura and RepetierHost?
No… Slicing with Simplify3d. Running on OctoPrint.
Try inside->out, and outside->in for perimeters. Compare the two and let me know which you like better.
I already know the answer, I Just want to see if it makes the difference I am expecting :slight_smile:
isn’t this related to the 3D model (inverted face) ?
just uncheck the box on the left that says show retractions
