I'm not sure if my problem is with Chilipepr or with GRBL 1.1,
I’m not sure if my problem is with Chilipepr or with GRBL 1.1, but all of my jobs are scaling about 25% no matter the units settings being MM or inches.
Can’t seem to sort the issue despite trying to isolate each piece. Any thoughts? Currently it’s engraving about 2" while the design and Chilipeppr state 7".
Probably your mm per steps setting
Thanks John! Found someone with the same machine and I noticed my custom GRBL settings didn’t stick.
