I'm making spaghetti monsters.
I’m making spaghetti monsters. Anyone can help?
Check extrusion length, and filament diameter.
Calibrate your e steps and check temperature
i had the same problem , turn to be the plat motor bully is losing position in the motor shaft , you need to make small hole in shaft so the lock screw in the bully can stay in position , or tight it harder
Love this community. It’s one of the most helpful I’ve seen. Kudos to all those who help.
Thanks to all. I think I’m honing in on the problem.
