I’m looking to get a new machine, but not sure which one to get. I’m fed up with my Printrbot Jr. Here are my requirements:
Less than $1500
Printing area of 180 x 180 x 180mm or larger
Uses 1.75mm filament (I still have 6 nearly full spools of it)
If possible, has a wait time of less than a month
If John cant stand his jr then a rostock or even an i3 will be just buckets of fun. I think a prebuilt makergear m2 is the next best at $1700 although the bukobot or ultimaker would both be good machines for entirely different reasons.
@John_Schneider No not at all. Ok, that was sarcasm too. Another option is the Lulzbot AO101 for about $1700 assembled. Not a huge fan of their hotend in theory but they made some improvements to it recently. Overall the machine is the most standard in many respects as a prebuilt machine with the horizontal x, wades style extruder, etc. They also do a good job supporting open hardware. The 90 is a bit of a connoisseur’s machine… it seems amazing and you just cant argue with nophead but some things seem a little nonstandard about it like the ribbon cables and little dsub connectors everywhere.
@Diego_Porqueras_Deez , how much longer than a month wait do you think it’ll be? I was strongly considering the bukobot, but then discarded the notion after noticing it was only 3mm.
