I’m looking at the BOM on github for the truggy model, and the only source for cvd’s is http://www.conrad.com/ce/en/product/231121/. The problem with that is they dont ship to the USA. Any USA users know of any good alternative sources/products?
Not that I know of. The conrad parts are really expencive and there are other parts similar lengths but they don’t work unless they have very similar bucket shapes and lengths of which none have been found so far.
There are some modified files to work with CVD’s from hobbyking kicking around in a comment to the same question asked previously in this group.
Look at the wiki. There are some options on there.
on hobbyking you can find some, they look pritty much similar, but probably youll need to experiment a bit. i got the ones from conrad and in my opinion they could have been a little bit longer. i shortened the whishbone a little (i think it was 3 mm or so)
or check on ebay “drive shaft cvd 1:10” should fit more or less, you might need to take some measurements and experiment
Best
Helmar
If you go for all metal differential you can go with HSP 188015 easy find on ebay from china.
and for information the HSP 188015 didn’t fit the plastic diff version
Ive been looking for alternative but what is the diameter for the axle and the hub?
@Avy_Lancry_Glawen what differentials we buy?
@Carlos_Martin I run with
2x HSP 02024 Diff Complete
2x HSP 06022 87mm Drive shafts
and 1x Central Diff.Complete (1Pc/Bag) – A2016T-33154 from hobbyking
@Avy_Lancry_Glawen thx for reply, but…
We need print some aditional parts ? or standard openrc truggy original parts 3d work perfect with this diferentials?
Thx again
@Carlos_Martin Look for the all metal OpenRC part for right printed part
