@Wolfmanjm I see - so Z needs to increment / decrement after every run. Any suggestions on how this can be implemented easily? Maybe I can do something in Octoprint. Does this command skip the buffer - so that the change is instantaneous, or it takes into effect only when it reaches the head of the buffer.
Apologies for so many questions, but this is my first time moving to Smoothie, and am still figuring out stuff
@Wolfmanjm so doesn’t skip the buffer - I can probably work with that. And, as a last resort, do things properly and not act like a lazy ass :-). Thanks for your help.
Was revisiting this; but turned out that after changing the coordinate system offsets using G10 L2, you need to even issue a G1 Z command. In effect to get psudo-babystepping you would have to give a G1 Z (first layer height) in addition to the G10 L2 command with an incrementing Z value…
