Im hoping someone can help as l am close to taking a hammer to this machine . The issue is that my laptop wont detect the machine, I know that a few people have had similar issues. I have done all the usual stuff so making sure the machine model and id is correct in corel draw etc . I have replaced the motherboard, so im pretty sure its a driver issue but as everyone knows , instructions are a bit thin on the ground so dont know if im missing a step or im installing the files. I have also tried it on a different laptop and it still wont detect. Any help would be very much appreciated.
There seems to be a folder on the original K40 Software CD (that shipped with mine) that is\The latest CDR software\Laser engraving drive.
In that folder is a Setup.exe & a couple of .sys files & an .inf file. I believe these are drivers that may be required? I don’t recall installing drivers myself, but it was a long time ago when I did it.
Windows 10?
what about windows 10?
A new update to Windows 10 won’t allow for unsigned drivers
you can override this in the settings though and will allow the drivers to be installed and doesnt ecplain why when i plug the laser in , none of the laptops detect any form of device at all. even without a driver it should detect that some form of hardware has been plugged in
nope have tried 3 of those as well
What is the controller type? Is it the m2nano or the moshi?
You may have a faulty controller…
M2nano
Might be worthwhile contacting the seller to ask for a replacement controller (if you recently purchased it). Or see if someone on the group is semi-local & has one that you could test to see if that is the issue.
By controller do you mean the motherboard? If so this has been replaced
It may have already been done/said but note that for me I had issues often. plug in the usb into the computer then turn on the laser, but MAKE SURE the laser power switch is on lol(the USB power wasn’t enough for the board to initialize and register). Facepalmed myself on that one a couple times .for safety i dont press laser enable until i am ready to run a job.
The racket the psu makes you certainly know when it’s switched on
Did they send a replacement dongle along with the board? Not sure if the USB key is paired with the boards or not
@Alex_Krause there was no new key, I don’t think they are paired to the board anyway hence why you have to put the I’d of the board into the corel laser software
Can you read the output of the cable that connects the psu to the nano board to make sure the PSU is giving the nano board 24v and 5v power?
nope dont have anyway to test that
Did you ever get this sorted out? I just got a machine delivered Friday and seem to have the same problem. I have aligned the laser, but can’t connect to Windows 10. Each time I run CorelLaser, I get an error “Engraving Machine is disconnected”. I do not see the machine in my devices. I have set the ID and even tried deleting the last character and replacing the USB cable as some posts have suggested. I have checked all of the connections on the board and within the unit. I have tried running CorelLaser as an administrator. None of these have worked. Open to any suggestions…
@Cherisse_Nicastro I disconnected the 5v wire coming off the power unit going to the motherboard, that fixed mine as I saw on some of the pics posted here that some had three wires and some had 4. Worked for me
