@Daniel_Garcia I originally did try 1.6.9 but the same symptom occurs, 1.6.8 does the same. I switched to 1.6.5 as the FastLED documentation said it was tested with that.
It’s probably something I’m doing wrong, but I can’t figure out what.
Even though there’s mention of FastLED 3.001.000, I’m using 3.1 according to the README file. Here’s the output from Arduino IDE:
Arduino: 1.6.8 (Linux), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
In file included from /tmp/arduino_modified_sketch_877697/ArrayOfLedArrays.ino:2:0:
/home/steven/Arduino/libraries/FastLED/FastLED.h:12:2: warning: #warning FastLED version 3.001.000 (Not really a warning, just telling you here.) [-Wcpp]
/tmp/arduino_modified_sketch_877697/ArrayOfLedArrays.ino: In function ‘void setup()’:
ArrayOfLedArrays:17: error: ‘PIXIE’ was not declared in this scope
FastLED.addLeds<PIXIE, DATA_PIN, RGB>(leds, NUM_LEDS);
ArrayOfLedArrays:17: error: no matching function for call to ‘CFastLED::addLeds(CRGB [1], int)’
/tmp/arduino_modified_sketch_877697/ArrayOfLedArrays.ino:17:59: note: candidates are:
/home/steven/Arduino/libraries/FastLED/FastLED.h:172:129: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER, unsigned char SPI_DATA_RATE> CLEDController& CFastLED::addLeds(CRGB*, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER, uint8_t SPI_DATA_RATE > CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
/home/steven/Arduino/libraries/FastLED/FastLED.h:172:129: note: template argument deduction/substitution failed:
ArrayOfLedArrays:17: error: template argument 1 is invalid
/home/steven/Arduino/libraries/FastLED/FastLED.h:184:95: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN > static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
/home/steven/Arduino/libraries/FastLED/FastLED.h:184:95: note: template argument deduction/substitution failed:
/home/steven/Arduino/libraries/FastLED/FastLED.h:196:113: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER > static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
/home/steven/Arduino/libraries/FastLED/FastLED.h:196:113: note: template argument deduction/substitution failed:
/home/steven/Arduino/libraries/FastLED/FastLED.h:209:56: note: template static CLEDController& CFastLED::addLeds(CRGB, int, int)
template static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
/home/steven/Arduino/libraries/FastLED/FastLED.h:209:56: note: template argument deduction/substitution failed:
ArrayOfLedArrays:17: error: wrong number of template arguments (3, should be 1)
/home/steven/Arduino/libraries/FastLED/FastLED.h:213:74: note: template<ESPIChipsets CHIPSET, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, EOrder RGB_ORDER> static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
/home/steven/Arduino/libraries/FastLED/FastLED.h:213:74: note: template argument deduction/substitution failed:
ArrayOfLedArrays:17: error: wrong number of template arguments (3, should be 2)
/home/steven/Arduino/libraries/FastLED/FastLED.h:217:97: note: template<ESPIChipsets CHIPSET, EOrder RGB_ORDER, unsigned char SPI_DATA_RATE> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, EOrder RGB_ORDER, uint8_t SPI_DATA_RATE> static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
/home/steven/Arduino/libraries/FastLED/FastLED.h:217:97: note: template argument deduction/substitution failed:
ArrayOfLedArrays:17: error: invalid conversion from ‘int’ to ‘EOrder’ [-fpermissive]
/home/steven/Arduino/libraries/FastLED/FastLED.h:244:25: note: template<template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET, unsigned char DATA_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
/home/steven/Arduino/libraries/FastLED/FastLED.h:244:25: note: template argument deduction/substitution failed:
/home/steven/Arduino/libraries/FastLED/FastLED.h:250:25: note: template<template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB, int, int)
/home/steven/Arduino/libraries/FastLED/FastLED.h:250:25: note: template argument deduction/substitution failed:
/home/steven/Arduino/libraries/FastLED/FastLED.h:256:25: note: template<template class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB, int, int)
/home/steven/Arduino/libraries/FastLED/FastLED.h:256:25: note: template argument deduction/substitution failed:
/home/steven/Arduino/libraries/FastLED/FastLED.h:292:25: note: template<template class CHIPSET, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
/home/steven/Arduino/libraries/FastLED/FastLED.h:292:25: note: template argument deduction/substitution failed:
/home/steven/Arduino/libraries/FastLED/FastLED.h:298:25: note: template<template class CHIPSET> static CLEDController& CFastLED::addLeds(CRGB, int, int)
static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
/home/steven/Arduino/libraries/FastLED/FastLED.h:298:25: note: template argument deduction/substitution failed:
exit status 1
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
