Im having trouble when trying to level my print bed,
Im having trouble when trying to level my print bed, I level it out but when I start printing it just sprays out filament 3-4 mm above the print bed!
This is my first printer and I am quite frustrated, do you guys have any idea what the problem might be?
Sounds like your Z offset for your probe is off. What printer?
@Adam_Steinmark it’s a prima creator P120, basically a monoprice select mini
My printer does this as well, it is to purge the hotend I belive. Even so, it should nit create trouble with your print in any way, its part the gcode, and can be removed.
@Adam_Steinmark thanks for the help! It works now :smiley:
