I’m having some trouble updating the x & z steps per mm values in my repetier config. I’ve changed the values and reflashed the board(smoothie), but my printer is still printing with incorrect x and z steps. Is there another step that i’m missing?
Maybe you updated wrong area on the firmware configuration file? I mean… On Marlin I found only one area to set this on the configuration.h
Solved it! lines in the header from my slicer were overriding the steps per mm values. Thanks anyways!
