I’m having some serious problems with my extruder, and I can’t seem to figure out what exactly I am doing wrong.
I get about 15-20 minutes into a print and my extruder starts jamming up on me, almost as if my stepper isn’t getting enough current, I adjust the trimpot on my driver and sometimes it helps, but only ever for a minute or two at most. I don’t think it’s torque unless my stepper is failing, as I am using an E3D v5 which is correctly assembled, and a direct drive system using a Tatsu drivegear from Deezmaker and this design for the cold end.
any input on what could be going wrong with my extruder?
Filament quality is an important consideration. Also check if you can hand extrude. I.e. once it is hot enough push it by hand and extrude instead of using the stepper. See if it extrudes without much effort from your hand.
