I’m having a little trouble figuring out how turn a photo into a working engraving project with laser draw…any help would be greatly appreciated.
Basically you just convert it to black and white and increase the contrast. Dithering helps. Do a google search for how to engrave a photo with a laser. You tube has a few specifically using corel or photoshop. After that it’s just asjusting your machine speed & power to get the wanted results. Here’s a couple links but there are others, some better.
Thanks Marc G.
Change the color index to two, that way you get only black and whit pixels (dithering)
This was posted recently http://www.instructables.com/id/Enhance-Your-Image-when-Reverse-Laser-Engraving-on/?ALLSTEPS
graphic format supported : DST,PLT,BMP,DXF,DWG,AI, LAS,etc.
compatible software:Coreldraw,photoshop,autocad, tajima,etc.
for bodor laser cutting and engraving machine
