I’m having a huge problem doing a bed leveling on a Da Vinci XYZ printer. Does anybody have an tips or tricks. Seems like I’ve adjusted it almost a 100 times and now I’m still off the tolerance by > 5?
Are you 110% sure that the bed is flat?
Sounds like an uneven bed. Z
Print something like a large circle. As it moves round on the outer edge monitor the bead. Adjust the bed as the print head moves. If it squashed to much adjust down and not enough adjust up. Not high tech but it works. I’ve seen the davinchi leveling process it’s painful.
Do the manual leveling. Look for it on youtube
DONT USE THE AUTO LEVEL. it is more trouble than it’s worth and you can get a more accurate level doing the large area print
Thanks so much! I’ll try these approaches and see if they work.
