I'm getting some strange "spikes" on entry points when cutting from shape to shape.
I’m getting some strange “spikes” on entry points when cutting from shape to shape. A thin, raised line appears where the head moves to cut the next shape on what should be a smooth edge. I’m using a K40 with smoothie, cutting acrylic between 6 to 8mm/s. I didn’t have this problem before when using the horrible Chinese software. If I select shapes individually and cut them one by one as separate jobs, the problem goes away, this takes too long of course. Is there a remedy for this? Or I thought about adding a pause in the G-Code once the head moves to the next shape in the job? Is that possible? If so, what line would I add? I should add, this doesn’t happen on all objects I cut, just on some.
Cheers!
Spike…
Try reducing your firmware’s max speed setting
