I'm getting a few people wanting me to put together a build manual for
I’m getting a few people wanting me to put together a build manual for my http://3done.co.za printers . I’m looking for hints on what should and shouldn’t be in there. I’d like it to be easy to follow and but not bloated. I’m a bit of a build a frame… right next kind a person. And it occurs to me some people may want more instructions. But again people may not want me to explain how to calculate the lengths based on build volume. From people that have built from kits can you tell me what you did and didn’t like about build instructions.
A fellow South African! Where you based and where are you ordering your parts from? I’m west JHB :slight_smile:
The most important thing about build manuals is planning the order of doing things and eliminating ambiguity.
Watch out for things like use of screws of identical size but different length. Emphasise what components are required at each stage.
Consider breaking the build into modules to encourage the builder to do things in stages and check their work as they progress.
Try to avoid the build and set aside for later mentality. It is better to build in an organised flow mounting sub-assemblies as they are completed.
Don’t underestimate the need for a post-build calibration and initial run section. The worst build manuals leave the builder with a sense of “OK, I’ve built it, now what do I do next?”.
You probably don’t want to do this but a troubleshooting section will be required. This should cover the commonly encountered build problems and provide solutions. You could maintain this online and just provide a link in the manual.
At the outset be sure to detail the skill level and tools required to complete the build.
Thank you @Neil_Darlow been typing up a 1st draft of it today, and will definitely add as you suggested.
@Ian_Holden
I’m in Randburg. It is always nice to find other locals on here.
Ah I work in Cresta :slight_smile: so just around the corner. Nice project you got there!
