I’m curious if there is a way to set certain values to be on when redeem starts? Like start up routines? Like having Fan 3 on ar start up. I use fan 3 for my lights.
Hm… not automatically, but there is a way to do it. Redeem sets up a couple of pipes that you can echo commands to with a boot script. Out this in a boot-script:
echo “M106 P3 S255” > /dev/testing_noret_1
Thanks, I’ll give that a try.
in Octoprint’s settings there is a tab “GCODE Scripts” - use a field called “After connection to printer is established” (which happens automagically ) and put your gcode there
