I’m converting my router cnc from mach3 over to chilipeppr running grbl 1.1 and I’m having problems setting up chilipeppr with grbl how do you do it? also is there a manual showing how to setup chilipeppr?
There’s a pretty good amount of videos on Youtube on running ChiliPeppr. I think that could help you get going.
john thanks for writing back. as for Youtube there is lots of stuff for chilipeppr. but nothing on how to set it up. or a user manual I have been looking for some time now .
@allan_pierron Hi, you don’t really need to do much setting up in Chilipeppr.
- Download and run the serial port jsonserver (same or different computer)
- Start (Chilipeppr jpadie workspace)[http://chillipeppr.com/jpadie]
- Direct Chilipeppr to the server (bottom right widget)
You will need to configure grbl settings for your mill.
