If my printer is unable to succesfully print off a set of Herculien Parts
If my printer is unable to succesfully print off a set of Herculien Parts in ABS
Whom here could print me some Herculien parts in ABS? Color doesnt really matter.
What parts do you need?
If my printer keeps up being unreliable…all of them for the herculien
I can print the mechanical necessities to get you up an running, just waiting on a couple PC panels so I can fully enclose my printer for high quality
ABS prints
that would be most appreciated. then i can forcefeed/ babysit my unreliable POS for the not so much needed bits.
all my parts are arriving mid nov - early dec im gettin an early xmas :’) hehe
just left to source are small things. like hobs etc. oh and the 24v psu. ( not sure if one on ebay is legit or good)
http://www.ebay.ca/itm/Mean-Well-MW-24V-18-8A-450W-AC-DC-Switching-Power-Supply-SE-450-24-UL-CUL-PSU/370888481015?_trksid=p2050601.c100085.m2372&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140211132617%26meid%3D2f901ae0edf140d396824f5e053894c7%26pid%3D100085%26rk%3D1%26rkt%3D4%26sd%3D370888481015%26clkid%3D683250862226277460&_qi=RTM2067267
It should be fine. Just don’t skimp on the the extruder. That ultimately dictates the quality at which you can print.
@Jim_Stone also that PSU is overkill. I really should update the BOM. Now that the bed runs on an SSR you are only driving steppers and the hot end from the PSU.
But Meanwell really makes great PSU’s.
hahaha you dont know overkill XD im currently running my printer from 12v 85a server PSU hehehehehe
so serious question. what psu would be fine? theres one in my area. it was just a lower wattage.
I recently used this one on the delta. Not a meanwell, but good quality and seems to work just fine:
Genssi 24V 14.5A 350W Regulated Switching Power Supply https://www.amazon.com/dp/B005CLDOW8/ref=cm_sw_r_other_awd_YRYkwbHTBSMWJ
But check the panel cutouts and mounts for the enclosure if you change PSU’s
would the 350w meanwell of the same range work then? usually when i build a pc i usually go overkill on the PSU as i cant figure out how much i really do need
@Jim_Stone should be plenty. I think even 300W would do it fine. But there are plenty of nice supplies in the 350W range to choose from.
yup. my current printer just let out the blue smoke. friend was near and spilled their tea into it :frowning:
so looks like i will need some halp on ALL the pieces. can comp for plastic used and shipping
@Jim_Stone I should be able to start printing them later this week. I will likely print the pieces in a combination of white and silver ABS
Thank you so much
@Zane_Baird what are you wanting for them btw. plus my cost of shipping of course
@Jim_Stone If you want I will print them at no cost (other than shipping) if you buy a roll of ABS in the color you want them printed and have it shipped to me. Send me a message and we can discuss the details.
