If anyone else has a mini lathe and was too lazy to get around
If anyone else has a mini lathe and was too lazy to get around to making a smaller hobbing tool to fit your lathe, here you go.
Originally shared by Jeff Keegan
http://www.thingiverse.com/thing:135887
If you have a mini lathe, lucky man!
I posted some time ago a link to a more home-made bolt using a Dreamel.
Yeah I made a few before with two printed mounts that held 608 bearings, screwed into a piece of wood, and I held the tap in a power drill. I also made heater barrels by with my drill press, which was far from efficient. Eventually I got fed up with using the wrong tool and put a lathe on my xmas list. :slight_smile:
