I’d like to start printing this, which are the correct STLs to print?
Also, Has anyone used other CVDs? The conrad ones at £25 seems a bit much for just 2, when for some vehicles they are on ebay for £8!
I should probably, generate a full “kit” of STL´s if i can find the time!
Thanks guys, going to print all the B2 stuff and then re-print anything that needs replacing with the new versions if/when I need them.
Not to sure on step files and exporting STLs, I only use SCAD.
I was about to complain about the STLs being broken then realised that my belt pulley on X was loose!
Printed all three diffs and servo holder at same time, took 8hrs 10! Only steering and gears left now. Can the gears be done with a 0.5mm nozzle?
