I will add a milling motor to my lasercutter based on GRBL 1.1e, arduino UNO and grbl shield v3. Did anybody have experience with this motor/motor controller board and grbl shield v3?
https://m.de.aliexpress.com/item/32614548923.html?trace=wwwdetail2mobilesitedetail&productSubject=32614548923&shortkey=uURr22aM&addresstype=600&
I don’t recomend it, I bought one a year ago, the controller burned after few days. Quality of controller PCB is very poor.
So far, I couldn’t find another type of controller that work with the spindle.
@ameen.nihad
Can you recommend any other spindle motor in this size?
Over the past two years I changed my spindle 5 times, I’m currently using this one:
I had same spindle before buying the brushless one, I was using it heavily (4-6 hours) a day almost every day, it lasted around 6 months before its brushes started to wear out and generate some noise which caused my stepper motors to skip steps, it’s not the best spindle but it’s suitable for light work, currently I don’t use my machine heavily as before and spindle is working fine for almost a year now.
Here is another link for original spindle with its manual speed controller:
