I was having a problem blowing my fuse after installing a new 220V/10A DPST
I was having a problem blowing my fuse after installing a new 220V/10A DPST switch on my control panel. I ended up having a faulty switch but it cost me a lot of aggravation coming to that conclusion. During the troubleshooting, I had to make myself a quick diagram for reference, because I learned my lesson a long time ago when it comes to trusting color codes and wiring standards from China. I went through checking continuity with the DMM while making this, just to be sure. I hope this helps someone in the future.
Wiring standards and China in the same sentence? Sober up my friend. :slight_smile:
well, at least they wear gloves… LOL!
On mine there’s a cooling fan (and two power outlets) wired parallel between the “red” wires. Which confused me for a moment because my multimeter was picking up 150Ω between the two.
Did you add the fuse, or is there one in there somewhere that I didn’t notice?
@TwelveFoot my AC plug has a fuse inside of it.
The fuse in the back of mine came stock… I’m glad it’s there. A cheap $3.00 switch off ebay almost cost me another hundred bucks. I just fished around on digikey for a good one, should be here monday :slight_smile:
