I wanted to know if anyone know the pitch on the pinion. I got a 48p standard but it was way off. I got a 48p metric Tamaya and it seems close and that is what I am using now but it is a little noisy and does not seem to engage all the way.
Noisy would be the gear mesh but what do you mean by engage?
I mean the end of the gear tooth on the pinion will not bottom out on the spur gear. I would back it off a bit so it was not to tight but there is a gap when fully seated.
You may not have the right amount of teeth… I the adjustment for mesh is as close as it gets and the teeth arent really really tight you need a larger pinion or spur. When set correctly if you hold the pinion still and move the spur it should move about .5-1mm. Too much or little will strip it
