I want to create a repository/ gallery of laser cutting and engraving jobs that you folks have run so that new users have a starting point to work off of and can compare results. Details in the linked original post.
Originally shared by Ray Kholodovsky (Cohesion3D)
I’d like to start a repository of benchmark laser jobs that new users can run.
So, if you’re up and running, here’s the idea.
You have a job that you ran. I’ll use rastering a picture as an example.
You have a picture of a boat that you engraved using LaserWeb with some DPI, beam diameter, and power settings. You share those values/ settings and show a picture of the outcome. You share the raw image, settings, and the gCode file.
We host a repository of such examples with the files accessible.
A newcomer is having difficulty dialing in their machine. They navigate to this repository. First, they run the image in LaserWeb with their existing settings, whatever those might be. Then they adjust settings to match yours and run the job again. Finally, they can run the gCode file you provided. Now they have a before, in the middle, and after set of engravings they can use to compare quality and performance.
Please contribute by sending a zip file with all that type of information:
-raw image file
-gCode output file
-a text description of DPI, beam diameter, power values, what material was used
-a screenshot of the entire LaserWeb window so people can see the actual job setup values.
Not to sound cynical Ray but do many people do that? In my experience many various communities (especially so where money is to/ could be made from someone’s designs, the artist is not very forthcoming with their design.
I will not lie, I probably fall into that category to an extent. I can think of a few dozens of my best selling designs that I would not easily share with the web. Not that things can’t be copied or replicated, but why tell the world of aspiring craftsman what works best for me I am thinking. I can certainly see people sharing their shoddy mediocre work, but keeping the good stuff private. Or is this repository meant more for personal projects to help other learn how to make? Such as ‘today I made an enclosure for my Arduino and this is how I did it’ type things?
Folks here are quite helpful to each other.
In any case, I’m not asking artists to submit work. I’m looking for benchmark jobs from people that run lasers.
-here’s some random picture I found
-here’s the settings I used in LW
-here’s the gcode file
Nice and simple, now a newbie can use this information to tune their machine to perform as well as the more advanced user.
Ohhh I understand. That sounds pretty cool then to help other out just learning to how manipulate their device settings. That sounds like something fun to contribute towards, hopefully there will be enough of an audience that we might even get feedback suggestions from the pros on ways to improve our own work submissions, great idea!
