I want to add an air assist to my K40 but I’m having troubles finding a cable drag chain that’s not too big…
I have some cable chains here but when folded they measure about 100m and that’s too big. I only have about 60mm or I lose working area in my K40.
Anyone here using an air assist in combination with a cable chain?
Do you happen to have a link to the cable chain you’re using?
@Ashley_M_Kirchner_No Are you the one with the chain running across the top of the gantry? I kind of liked the look of that, rather than my (the usual) setup.
I printed one of mine and it has a much tighter radius than the bought one. You can see both in the photo, the one on the gantry being the printed one.
Dunno @Domm434 , the 7x7 I’m using has a very tight radius. It looks even tighter than what you have printed there but it could just be the angle too. Being that mine is mounted on the top of the gantry, I needed to make sure the head can travel all the way to the front without the drag chain hitting the cover. It doesn’t, there’s still room if I wanted something with a less tight radius (which I don’t need.) Look at the video I posted in my first comment, somewhere around 1:30 you can see it in action.
It’s $3 (free shipping) for 1 meter of the chain. While I have a 3D printer, there are other things I do with it. Spending the time to print that just wasn’t worth it for me.
Wow… that is small Ashley, Mine is 10mm x 15mm a little big but works find. I live within 25 minutes of Lightobject andas I recall they may have one in between. Next time I go up there Ill have to check them out. Something in between would be nice to find. Also mine is like Phillip’s you can take off or add segments with a flat screwdriver.
Yep, the tube isn’t very big at an OD of 5mm. There’s plenty of room still left in the chain to add wires for the laser pointers I plan on adding later. I just bought 1 meter of it, split in half and run one above the gantry and the other half along the side.
@Domm434 I tried priting a cable chain on my ultimaker 3 but i can’t get them to move smoothly. It’s a very very tight fit. I had to use a lot of force to get them connected together and it’s not moving smoothly… can you tell me where you got the STL’s from?
@Andy_Knuts I’ve 3d printed cable chain before. It starts stuff, but once it’s run in it should be fine. I had to pull mine apart to clean the links. In the end, I just buy it now. For a few dollars, the time and effort savings where worth it.
