I use Simplify3D as my default slicer.
I use Simplify3D as my default slicer. But for the Cura users out there I made an STL of the bed for Eustathios. It can be used in Cura similar to the way the Ultimaker bed displays when you select that as your printer. To be honest it is just a waste of graphics resources… but it looks cool.
You define to use the STL inside the:
C:\Program Files (x86)\Cura_15.06.03\resources\settings"YOURPRINTER".json
Here is the STL: https://drive.google.com/file/d/0B1rU7sHY9d8qZmpvVHF4WnFXaDg/view?usp=sharing
I should also mention you put the stl file in the folder called:
C:\Program Files (x86)\Cura_15.06.03\resources\meshes\
… I think… I am away from my computer
You use it in simplify too?
@Joe_Spanier I didn’t know you could in simplify3d.
In the new 3 you can in you machine definition. I have a lulzbot bed in mine
I think Simplify has a place to put a machine STL but I haven’t tried yet. it’s in the machine manual configuration panel.
