I upgrading my printer (is called the g&c printer), i replacing all x,
I upgrading my printer (is called the g&c printer), i replacing all x, y and z axis with better ones. The x and y axis are almost ready. Posting some photos of the corexy movement to get some critics on my desing.
Some specifications:
3 x 15mm linear rail hiwin
5mm laser cut aluminium main plate
Use only one belt of 4 meter instead of 2.
Belt tension made on the motor support.
Both planes are on the same level, using a twiste on front. The belt do not touch because two bigger pulley are not on the same z level.
Only use printed piece to secure the belt on the carriage.
The carriage was made using 2 motor mount brought on ebay.
This ia about the same i want to do in terms of conversion of my corexy setup. http://www.thingiverse.com/thing:313095 i would reverse the motor pulley on the z axis to enable you to setup astrosyn motor dampeners. The are cheap and remove so much vibration. You could add the below the plate easily.
Wow looks great, can you share the files @Filipe_Campos
@Jean-Francois_Talbot my printer was dampers on boths x, y and z motors and i want to remove all the dampers. The reason for this is because i using 1/128 steppers that give a lot less vibrations and dampers introduce tensions variations on the belt.
@varun_s i will share all the files when the upgrade will be finished. I will put everthing on thinginverse
Looks good.
Nice design! My only very slight suggestion would be that you could move the y rails in to the innermost edge and the belts out to theoretically have the best case scenario to avoid racking. But I doubt it will be a problem. Good job!
@Brook_Drumm about the y axis, the y rails are outside because that was the only way i found to get the most possible print lenght on the y axis. This core machanism will go on the on a actual working printer that was 40cm by 40 cm of size. The plate was 46cm on the y and it will allow me to have a 31cm x 29cm. Because is a upgrade i doing and not a new printer there was lot of retrictions, if i was build a new one i will no doubt have done like you say.
My big concern about this upgrade is the bed. I upgrading a bed from 20x20cm to 31 x 29 and using only 2 rods and one motor using a cantiveled sistem. The atual bed use 2 x 12mm rods, 8mm lead screw with 2mm pitch and all metal structure. It will be upgraded with 2 x 16mm rods, 8 mm lead screw with 1,5 pitch. But not sure it the nema17 motor will have enough torque to move everything correctly.
Looks great. I am also trying to make similar but with 12mm rails and 25x25 bed.
Alijutt
