I tried something which is not working… I’m driving two LED strips from one data pin. One strip works ok, the 2nd has visual bugs which correct themselves eventually. I found Andrews FAQ from a few yrs ago which says mnot to do this… oops!
I’d like to do it correctly now… I guess that means one data pin per LED strip? Is there a way to clone the output to the second LED array easily I have so many subroutines that I’d rather not individually revisit. Any examples would be greatly appreciated.
Part of my problem was also with a basic full white pattern. Doubling the LED count resulted in a high current draw situation that put my power supply near its limits. I changed from all white to all yellow and life is good. I may go back and change to a lower brightness white later.
