I tried an experiment today, but it failed.
I paused to press a neodynium magnet into an internal cavity, then continued printing so the magnet was completly encapsulated in the part… Unfortunatly The extrusion temp of the ABS is much higher than the operating temp of the neodymium magnet (80degC as I later learned) , and the magnet lost almost all of it’s magnetism… another one for the useless parts bin (I’m gonna need a bigger bin soon)
The (important) metal parts will be fine. You’ll probably melt the plastic a little (at least enough to bond it), but I imagine it would survive. Those components need to be able to stand up to soldering.
@Normand_Chamberland
For this trial, I just found the layer number that was the end of cavity, and hit pause and retract at the right time… then continue after pressing in the magnet. A better method would be to add the proper statements to the GCode file.
I’m thinking of trying @Dave_Durant 's idea, but applying the pad on top of the magnet. If it’s thick enough, it should insulate the magnet, and still allow it to be print encapsulated. I’ll also need to lower the bed temp as I’m printing at 120 degC with Aquanet on glass
Between platform heat, latent heat in the recently-printed plastic, etc., I don’t think you’ll see that much improvement. Also, if you try to add acetone at those temperatures, it will boil.
I knew heat could demagnetize, but I thought it required much hotter temperatures (like several thousand C). Thanks for sharing and saving others the same grief.
try it with pla, and a high layer height.
with the much lower extrusion temp you might get away with it. I’d be surprised if the the magnet is getting anywhere near the temperature of the extruder, and plastic is not a great conductor of heat.
You’d have to reach 310C, possibly all the way up to 400C in order to demagnetize it.
Likely what happened, rather is that you’ve placed it too far into your printed object. Neodymium magnets, while strong, have awfully short throws to their magnetic field. Often less than 1CM. At most, you should have maybe 3-4 layers covering the magnet, no more.
@ThantiK The Curie temp is where the magnet completly demagnitizes. Wikipedia is a great information source, but I’m relying on the manufacturer’s information. It probably would have been prudent to check it before I tried to embed the magnet. The bottom wall thickness was only 0.4mm, but I’ve since cut the magnet out of the part, and I can assure you that it has at most maybe 1/4 of its original magnetic strength. The magnets that I’m using (K&J magnetics) begin to lose their strength at 80 degC. I’m pretty sure I heated it to over 120 degC. K&J does offer specialty higher temperature magnetics.
