Do I have the world longest single-piece 3d printed screw here @ 630mm total length?
Printed on #Techne, my custom built 3d printer based on the #Ingentis and #Eustathios printers. This is the 4th print I’ve done on her and took 8 hrs at .3mm layers, .6 nozzle and PLA material at around 50mm/s… Reckon I can go faster when I print the next one!
Screw is part of a “mini” (lol) planetary gear set we are printing other parts for on our large format printer at #3DGroup / #3DIndustries.
No you not I saw this month’s a news about a printer and the print a mens high puppet at once
But nice try >.<
Hope you share more infos/fotos about you’re project
I was passing a head shop the other day and that looks like a part on a bong that is in the window, but much taller. I’d like to see some close up detail of that printed part every 6 inches of height. Quite an accomplishment!
Thanks! Its a LITTLE fuzzy toward the top but still strong and functional, the only wobble I’m sure was due to the part itself being flexible at that length/width ratio…
