I still cannot g29 and expect a leveled bed. I am sure its something I have set wonky in my config or end stops… but I am about to rip my hair out trying to figure this out.
I have attached my current config, a log, and a video in multiple angles. Please help me solve this homing issue.
Note there is an inductive sensor (that works when hit over the aluminum tape if you look closely, the red light flashes). It is hooked up to Z2 end stop. It should also be noted that when I tell the printer manually to go to points 0,1,2 it goes correctly and over the tape, but when the g29 runs, it doesn’t go to the points as expected. Z is inverted because up is closer to the nozzle.
Lastly, I tried this on the master, and am now currently on the dev branch. Trying anything to work. I’ve had this controller since launch and still have yet to do a single print…
Send: G29
Recv: End stop X1 hit!
Recv: End stop Y1 hit!
Recv: Homing done.
Recv: End stop Z2 hit!
Recv: Homing done.
Recv: Found Z probe distance 0.00 mm at (X, Y) = (88.00, 10.00)
Recv: // action:bed_probe_point@[88.0, 10.0, 0.0]
Recv: Found Z probe distance 0.00 mm at (X, Y) = (88.00, 310.00)
Recv: // action:bed_probe_point@[88.0, 310.0, 0.0]
Recv: Found Z probe distance 0.00 mm at (X, Y) = (390.00, 150.00)
Recv: // action:bed_probe_point@[390.0, 150.0, 0.0]
Recv: Homing done.
Recv: // action:bed_probe_data@{“probe_type”:“probe”, “probe_data”:
{“y”: [10.0, 310.0, 150.0], “x”: [88.0, 88.0, 390.0], “z”: [0.0, 0.0,
0.0]}}
Recv: ok
[System]
machine_type = DinCore_XY
loglevel = 20
[Geometry]
axis_config = 2
bed_compensation_matrix =
1.0, 0.0, 0.0,
0.0, 1.0, 0.0,
0.0, 0.0, 1.0
travel_x = 0.45
travel_y = 0.4
travel_z = 0.3
offset_x = 0.005
offset_y = 0.005
offset_z = 0.0
offset_e = 0.0
[Steppers]
microstepping_x = 6
microstepping_y = 6
microstepping_z = 8
microstepping_e = 6
current_x = 0.4
current_y = 0.4
current_z = 0.9
current_e = 0.4
steps_pr_mm_x = 8.0
steps_pr_mm_y = 8.0
steps_pr_mm_z = 20.0
steps_pr_mm_e = 8.0
direction_z = -1
direction_e = -1
[Cold-ends]
connect-therm-e-fan-0 = True
[Heaters]
pid_p_e = 0.142762682705
pid_i_e = 0.002279643636
pid_d_e = 2.23512825109
pid_p_hbp = 1.58068224052
pid_i_hbp = 0.0329308800107
pid_d_hbp = 18.9681868862
[Endstops]
invert_x1 = False
invert_x2 = False
invert_y1 = False
invert_y2 = False
invert_z1 = False
invert_z2 = False
end_stop_x2_stops =
end_stop_y2_stops =
end_stop_z1_stops =
end_stop_x1_stops = x_cw, y_cw
end_stop_y1_stops = x_cw, y_ccw
end_stop_z2_stops = z_ccw
soft_end_stop_min_x = -0.5
soft_end_stop_min_y = -0.5
soft_end_stop_min_z = -0.5
soft_end_stop_max_x = 0.45
soft_end_stop_max_y = 0.39
soft_end_stop_max_z = 0.3
[Planner]
max_speed_x = 3.0
max_speed_y = 3.0
max_speed_z = 0.025
max_speed_e = 3.0
acceleration_x = 2.0
acceleration_y = 2.0
acceleration_z = 0.6
acceleration_e = 2.0
[Homing]
home_speed_x = 0.2
home_speed_y = 0.2
home_speed_z = 0.01
home_backoff_speed_x = 0.05
home_backoff_speed_y = 0.05
home_backoff_speed_z = 0.005
home_backoff_offset_x = 0.01
home_backoff_offset_y = 0.01
home_backoff_offset_z = 0.01
[Macros]
g29 =
M561 ; Reset the bed level matrix
M558 P3 ; Set probe type to Servo with switch
M557 P0 X88 Y10 ; Set probe point 0 (Bottom Left)
M557 P1 X88 Y310 ; Set probe point 1 (Top Left)
M557 P2 X390 Y150 ; Set probe point 2 (Middle Right)
M574 Z2 z_neg ; Enable endstop Z2
G28 X0 Y0 ; Home X Y
G0 X88 Y10 ; Move the X Y to safe place to Home Z
G28 Z0 ; Home Z
G0 Z8 ; Move Z up to allow space for probe
G92 Z0 ; Reset Z height to 0
G30 P0 S ; Probe point 0
G0 Z0 ; Move the Z up
G30 P1 S ; Probe point 1
G30 P2 S ; Probe point 2
M574 Z2 ; Disable endstop Z2
G92 Z0.3 ; Compensate probe offset
G0 Z0 ; Move nozzle to the lowest position
http://www.youtube.com/watch?v=EqyB7jAt888
